Batter was dead, i jumped many times to mow. Last time it it died while mowing. i changed battery, checked spark, turns over good but won't fire? could i have burned out the alternator or magneto?
I can see no reason for your Alternator to be blown, Unless you connected direct onto your alternator which would solve nothing.
1/. Check your Battery Terminals are Really Tightened, next check out the most likely which is normally under the Dashboard your Fuse box.
2/. Should your fuse box be all working then it has to be the cables or the connections to the magneto, get the magnet checked!
3/. I think your problem is on the Fuse Box. It would help if you could give me the age of this Machine. Best Wishes, Malcolm.
