Electrical Supplies Logo
How or where can I get another fuse and its cover for diesel Generator KDE 6700TA. I live in Mallorca, Spain.
How or where can I get another fuse and its cover for diesel Generator KDE 6700TA. I live in Mallorca, Spain. m
Kipor KDE6700TA Diesel Generator - 5,5 kVA. DIP Settings for US Model.
Question edited for clarity.
Question moved from Televisions
Easy way is to phone their Service Department.
https://www.google.com/search?q=kde+kipor+6700ta+dip+switch+settings
https://www.kipor-power.eu > Diesel Generators
Strong power. All diesel generator sets are equipped with KIPOR four-stroke engines, also the Kipor KDE6700TA Diesel Generator. · Advanced alternator winding.
KDE 6700TA - Diesel Generator »
https://www.kiporuk.co.uk > kde-6700ta-400-64-67
A new AVR(Automatic Voltage Regulator)delivers non-fluctuating power. Powerful KM186FAGET diesel engine. Optional electric starter.
KDE 6700 diesel generator won't generate
checking oil and filter on a running engine has nothing with power output check breakers if on then send out for repair
Run fault warning light on
Why Kipor generators have a lot of problem? I meet many question about Kipor generator.
I recommend you Cummins diesel generator
WHY THE KDE 12STA GENERATOR ARE SHOWS IN DISPLAY AUTO PROTECTION PROBLEM SHOWS IN DISPLAY AND THEN SHUT DOWN THE GENERATOR?
Hello, about shutdown generator question, please visit website www.dieselgeneratortech.com, find answer on "Search box", enter " shutdown" to search, then you will find answers.
And if you also need to purchase diesel generator set, the website is also good one for you reference.
Power went out motor goes no volts why
If the fuses are good, your AVR (Automatic Voltage Regulator) may have failed or (less likely) you may have lost the residual magnetic field in your armature. With the generator off and your circuit breakers closed, plug in a corded 120V drill into one of the household 120V outlets on the generator. Spin the drill's chuck quickly, by hand, several times; This introduces a small electric current to your armature, "field flashing" the generator. Start the generator and check if the generator is now producing voltage. Sometimes this works, sometimes it doesn't. If no voltage, then it's likely your AVR has failed. You can purchase these online at ebay for about $35.00-$50.00. Buy a couple of them; these AVRs have a high rate of failure.
Kipor 6700ta po5 code problems , diesel silent generator
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
6helpful
2answers
KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Top Diesel Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Diesel Electrical Supply Expert? Answer questions, earn points and help others
