Its not supposed to do that,read your manual,it only reads memory cards,,it plays dvds
Power Acoustik PD 103B
SOURCE: alpine indash reciever 1004
there is a wire on the back of the unit marked hook up 2 parking brake....what i did was ran that wire to a toggle switch and to the cigarette lighter ground and mounted the toggle switch on my dash...then all u have 2 do is flip the swith off and on and it tricks the player to thinking the car is in park and will play right away...
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
SOURCE: Just bought a used Yukon with a Power Acoustik
try putting a laser disc cleaner through the player it will clean the lazer allowing it to read correctly
best of luck
SOURCE: parking brake switch wire on a power acoustik double din
this use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
This is right from the website
Playback from DVD & CD of MP3 & MP4
Playback from 32GB SD/USB of MP3 & MP4
So yes it's supposed to play dvds, and mp4 videos
So do you have any ideas why they won't play?
The deck will show the movies on the display, so it will read the info on the file but it won't play movie.
Dvd works just fine.
