To Remove the Pedal From the Pedal AXLE:
1 Warm up the Plastic Pedal at the edge of the pedal axle up to 150 F.
2 With the tip of a knife loose the edges of the plastic pedal.
3 With a flat screw drive, inserted at the tip of pedal axle, pry off the pedal toward the curved edge.
To install the pedal in the pedal axle:
1 Support the base of L shape of pedal axle on a strong surface.
2 Insert the pedal in the pedal axle.
3 With a plastic hammer tap at the top of pedal, through the pedal axle. Only one sharp tap.
Unscrew them backwards
Testimonial: "These are not the screw on type. They are made of plastic and have clamp clips at one end. To me they look like they slide on to metal sleeve and clip on at the end. Can you check and let me know how to replace them."
