Check first the door/frame seal on the frame and/or door. It may be lose and have partly come off the frame/door in places. Check also the integrity and continuity of the seal all around the frame/door.and push back on if necessary. If difficult to push back on try lubricating it with hair shampoo or soapy water
Look at the frame where the door lock pins engage with the plates on the frame - especially in the draught area. The plates are held by screws and loosening the screws and moving the plate away from the door then tightening the screws may cure this.
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
when in the cleaning mode the door lock will engage to make sure the heat does not get out. if it will not engage make sure there is nothing blocking the lock.
Does this seem to be getting worse (have to turn key on and off more than before to start?) Your starter is on the way out. Replace it before it won't start at all.countrycurt0
