Hi Elaine, The EasyShot stapler is a bottom load stapler. Please follow the steps below to make sure you are loading the staples correctly.
- Turn the tool upside down so that you can read the text "use light duty narrow crown" on the bottom of the magazine
- Open the magazine of the tool
- Place the staples inside the channel (not on the back of the magazine rail)
- Close the magazine.
Attached is a picture so you can see where to place the staples.
If you are still having trouble please contact our customer service department and we can assist you further.
[email protected]
Thanks
Thank you so so much for the diagram. I have been trying to load this thing for 3 hrs, the wrong way...very odd strange way to load a staple gun.
Glad we could help!
what staples does this take? Thank you.
SOURCE: staples not reaching the front of easy shot
There are several things that can cause this.
Check to make sure a staple or foreign object has not lodged down near the front of the unit. Preventing the staples from reaching the front.
Sometimes a miss fire will curl up a staple and cause a blockage.
Also check to be sure the staples you are using fit this unit.
Check to make sure the staple legs do not bind but slide easily.
Also check to make sure the ram is not jammed in the down position.
This will also prevent staples from reaching the tip.
You may have to send the unit in for service.
Hope this helps
