Here are the steps to properly install the spring in a Shakespeare Synergy 2001S reel:
Remove the spool from the reel.
Locate the bail wire assembly on the side of the reel.
Take the spring and slide it onto the bail wire assembly. The smaller end of the spring should be facing towards the reel.
Hold the spring in place and reattach the spool to the reel.
Test the reel by pulling the line out and then closing the bail. The spring should be under tension and hold the bail in place.
If the spring is not holding the bail in place or is not properly installed, the reel may not function correctly. If you are having difficulty installing the spring, it may be helpful to consult the owner's manual or a professional for assistance.
Shakespeare Fishing and Pflueger Fishing are now owned by Pure Fishing. As such, all the newer parts will be listed in one section under Ambassadeur Parts.
You might want to check the numbers you provided. I found this site to have a lot of diagrams for the manufacture you provided. Mikes Reel Repair Schematics
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
