My dishwasher is coming on but without any water. There is plenty of salt in and water in a salt dispenser but water is not coming in. Dishwasher will start on regular program but then after about 5 min will skip to pan program and stay there making a strange noise but no water is coming in. This is a built in dishwasher into the kitchen unit. I've looked through everything what I could to see whether is blocked and seems fine so not sure what would be the next step?
SOURCE: How to fix a panel to a semi-intergrated dishwasher
Contact the following address of G.E for their assistance http://www.geappliances.com/service_and_support/contact/ Good luck
SOURCE: Dishwasher just draines and nothing else??
this sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
SOURCE: Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
SOURCE: hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Please dont forget to vote this answer was helpful
Many thanks
