Imicro IM35SATABK 3.5" SATA-to-USB2.0 External Hard Drive Enclosure Black : IM35SATABK Logo
Cezar Garcia Ho Posted on May 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I MAKE THIS DRIVER TO WORK WITH WINDOWS 8?
Jay Plesset
Level 3:
  • Imicro Master 2,942 Answers
  • Posted on May 27, 2015
Jay Plesset
Imicro Master
Level 3:
Answers
2942
Questions
Helped
667824
Points
9879
What happens when you simply plug it in?
Imicro has lots of drivers:
http://www.imicro.com/index.php?ui=drivers
2helpful
2answers
I lost HP drivers or Windows 7 drivers when I installed Windows 8.1, where can I find the drivers?
If you are using Windows 8, most probably your Windows 7 drivers wont work.
You can find the drivers for Windows 8 of your original HP components in HP website
See Support - Download Drivers
Driver windows 8
All drivers for Windows 8 are available on the Microsoft website. Since Windows 7 all drivers need certification, from Microsoft and then you can download them there. All other drivers offered via other sites, could still work fine on older operating systems, but not on Windows 7 or 8.x. So older hardware can't be installed, unless you get certified drivers form Microsoft.
2answers
Pebble 3 windows 8 driver
Use the pebble 4 driver. I am using windows 10 and have tested on 8 as well. Download the Pebble 4 windows 8 driver and it will work fine.
Usb driver qhm500 8lm Sir i want drivers for
Hello
Currently, there are no Windows 8 drivers fo rthe QHM500-8LM PC camera (16 Mega pixels).
I would suggest downloading the drivers from the company web site:
http://www.qhmpl.com/Download-Drivers.html
....and save them to the hard drive. Once saved, right click the driver and choose PROPERTIES. From the new window, click the COMPATIBILITY tab at the top. In the COMPATIBILITY MODE section of the screen, enable this and choose the OS that the driver is listed to work with.
For example, if you download the Windows XP driver, set the COMPATIBILITY MODE to Windows XP Service Pack 3. If you download the Windows Vista driver, choose that OS.
Until a specific driver is created for this hardware, this will be the only way to get it to work with Windows 8.
Bluetooth not working on windos 8
Lenovo do not have Windows 8 bluetooth drivers on their support site.
You could try loading the WIndows 7 drivers (Broadcom Bluetooth Driver for Windows 7 32-bit or 64-bit)
10helpful
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
1helpful
2answers
Windows 8 drivers for m7250n
If you run the Windows 8 update advisor (available on the microsoft website)on your computer you may find that the hardware is too old for windows 8, as it was built to run windows XP. The only way round this would be to update the graphics and add an audio card that is windows 8 ready. I hope this helps.
4helpful
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
2answers
After update to windows 8 - drivers not working for asus k50ij.
Windows 8 is brand new and they may not have the drivers that you need for your computer on line. You may need to call them and ask them to send you a cd/dvd with the drivers for your computer. It is not always wise to upgrade your computer immediately when a new program such as windows 8 comes out. My advice to you is to reinstall your last windows back on your computer for now and if you want to upgrade to windows 8 check to see if all the drivers are available ahead of time, before you upgrade.
Top Imicro Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Imicro Computer and Internet Expert? Answer questions, earn points and help others
