SOURCE: Brand New Chi flat iron! No light, no heat, no
Have you checked it on different plug ins? I realize this sounds silly, but I had the same problem once and had a fit...all to find out my plug in had tripped. Bathrooms usually have those plugs that have the little button to reset the current. Maybe if you try that and different plugs.... If not, I would take it back as it is obviously defective. May have a bad connection, short, bad fuse, etc, and you would not want it anyway because it would not be safe.
SOURCE: My chi flat iron is
Try resetting it. Sometimes that can fix the problem. Make sure it's not a damaged cord. If it is, let me know and I can help you out with it. If it's not that, depending on how long you've had it, you can probably return it for another one.
SOURCE: I have several "Chi" Flat irons that no longer
When the flat iron does not heat up, it is usually the ceramic fuse that is located under one of the heating elements. I fixed my daughter;s CHI flat iron for $1.97 with a ceramic fuse I bought at Radio Shack.
SOURCE: Just bought it online and
Flat irons can also be repaired by sending to Flatironrepairs.com. You should check out the site for further information.
SOURCE: I have a working chi flat iron but it broke at the
Hi - check out www.flatironrepairs.com. They repairs CHIs.
