Question about Panasonic VIERA TC-P60ST60 60" 3D Plasma TV 1920x1080, 60 Hz, HDTV, 3D
7 led blinks. Which board do I need to repair?
    Top Expert:
  • Panasonic Master
  • 76,115 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Posted on May 27, 2015
2 Suggested Answers
SOURCE:
bugoy31
  • 1238 Answers
SOURCE: 7 blinks on led light
power supply faulty indication
Posted on Jun 21, 2012
Toshiba hdtv 37rv530u fails flashlight test. Green light on main board lights up inverter board flashes a blue led twice. Can the led screen itself go bad ? Or do I have multiple boards bad?
http://electro-medical.blogspot.com/
Apr 30, 2016 | Toshiba 37RV530U LCD TV
Sanyo tv troubleshooting
Hello, the good thing is that the led flashing is a blinking fault signal, the blinking means there's a faulty circuit. here's what you may want to do if your semi electronically inclined find a online service manual site, and at times it is possible to try a free manual search for your specific model,. the amount of times the light blinks will determine the faulty board. exchanging that board or repairing the faulty components it the tricky part. working at high heat levels and for extended periods of time may overheat and damage internal circuits and this is typical with these flat screens. but different manufacturers have different blink codes so it's a model specific manual you will need for this repair, and as in the other previous answers you may want to consider shipping/part cost/ before you go about servicing it. If you can handle this type of repair check auction sites for the boards it is way cheaper than service center pricess for boards, hope this helps.. have a great day.
Apr 25, 2014 | Televison & Video
Red LED blinks four times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 26, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Blinking led
Free diagrams unlikely to be available take the board's out and check for blown capacitors following good antistatic procedures and decide from there
Or find a good independent repair specialist to do the work and set your self a budget
My sharp aquos stopped working with a blinking power light £2000 was the repair quote for a new board and LCD panel for a £699 TV after they tried the capacitor replacement
Jul 01, 2017 | Sharp AQUOS LC-40C32U 32 in. LCD TV
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Panasonic VIERA TC-P60ST60 60" 3D Plasma TV 1920x1080, 60 Hz, HDTV, 3D Logo
153 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
