Sounds like your carb is not getting gas to the engine and needs cleaned..shut off your fuel supply and slowly remove the bowl from the bottom of the carb..it should be full of gas if not It is the float valve is stuck it is connected via a small pin...remove the pin and the valve should drop from its seat...clean with air and replace the same order you removed..now open the fuel supply and fuel should flow steady then slightly push the float valve up it should stop the flow..and flow again when released..put the bowl back on..if problem still exists then the very small fuel jet inside the bowl will need removed and cleaned..it is normally located next to the float valve secured via a small flathead screw followed by. A spring..a little tricky to get at..but take your time can be removed and cleaned using a needle..you may want to do this when cleaning the float valve...or may want to buy a rebuild kit..it replaces all these parts..good luck.
Testimonial: "Thank you! I appreciate your help.I will be back in a couple of weeks as I am travelling."
Pull gas line from carb, fuel or not. Come back if have fuel
