YOUR ISSUE SEEMS TO INDICATE TO AREAS TO LOOK INTO THE NON WASH OR NO AGITATION USUALLY IS DUE TO A BAD WATER PRESSURE SWITCH, THE NO DRAIN NO SPIN IS USUALLY DUE TO A CLOGGED PUMPED OR IMPEEDED PROPELLER, ARE U SURE U CHECKED IT WELL? THE ONLY OTHER THING COULD BE IS UR CONTROL BOARD IS MIS COMMUNICATING WITH UR DRAIN PUMP?
SEE PICS
machine starts, fills with water & then nothing... - machine-starts-fills-water-nothing-l0aezfktzb4tbeszt3mrtc2e-3-27.jpgnothing-l0aezfktzb4tbeszt3mrtc2e-3-20.jpg" alt="machine-starts-fills-water-nothing-l0aezfktzb4tbeszt3mrtc2e-3-20.jpg" class="h_mi" />
Testimonial: "Thank you! pictures helpful too. I'm wondering if the problem is as you said, the control board miscommunication with the pump. As the pump is definitely clean, nothing at all in it - in fact, removed pump and hooked it up to a power source and it works fine. So put it back into the machine - so far , so good. Almost as though it has been reset. But this is the third time have done this process & it always works fine for a few washes then the same problem of not draining water occurs. Hope this time is different! Appreciate your help!"
if ur pump is electrical as well did u check it for full voltage it may show well on a meter test for ohms continuity but fail mechanically or electrically? if its not getting the full voltage or is shutting down due to voltage issues from the coils u will get the same thing so it may not yet be ur control board but I suspect control board can be the issue as well?
