When you are taking ownership or resetting permissions, there is a checkbox that will allow you to apply these settings on all subfolders and objects. The system will rip through everything and reassign ownership/permissions for everything under the originally selected object.
This
can occur if there is a folder permissions issue or some settings
within the Blu Ray Player which might cause this. It could also be the
security program blocking the share.
A
few things you can try is creating a separate shared folder on the
desktop rather than using the shared documents and then try accessing it
from the player.
You can also try to disable your firewall and security program and then try accessing the shared folder.
Try turning off user account control and check.
You might also be able to resolve the problem by taking ownership of the folder.
To take ownership of a folder
1. Right-click the folder that you want to take ownership of, and then click Properties.
2. Click the Security tab, click Advanced, and then click the Owner tab.
3. Click Edit. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
4. Click the name of the person you want to give ownership to.
5. If
you want that person to be the owner of files and subfolders in this
folder, select the Replace owner on sub containers and objects check
box.
6. Click OK."
Here the source
Regards.
Ginko.
