SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
SOURCE: Stackable Washer Dryer won't fill with water
hi
first thought would be water soleniods but it is unlikely that both would fail you could try just selecting one temp and then swaping hose and select the other temp if it wont work on either then i would think it is not a sol. problem, lid switch could cause it not to fill also but you did say it would spin so that will rule it out ,its coming back to a module problem ,something to ponder on
cheers grant
SOURCE: When washer fills it does not stop unless done manually
HI, i recommend testing the timer/control device for faults. make sure it is spinning and not shorted. if the timer/control device is in good condition, this will confirm a serious fault in the water valve assembly(inlet). replace this device in this case.
SOURCE: the tub has a crack stackable washer machine.told
If you bought it brand new in 6/08, try calling Frigidaire yourself and see if they will replace the tub for you. It can't hurt to try.
SOURCE: stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Testimonial: "Suggestion worked, but didn't really snap off. Had to wiggle dispenser & finally able to snap it out. Cleaned with a toothbrush and snapped back."
