Olympus WS-100 Digital Voice Recorder Logo
Margarita Landry Posted on May 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't erase on my olympus WS-100
I have tried to erase my files and cannot do so. Now, the machine is of no use to me unless I can erase.
Jay Plesset
Level 3:
  • Olympus Master 2,942 Answers
  • Posted on May 26, 2015
Jay Plesset
Olympus Master
Level 3:
Answers
2942
Questions
Helped
667485
Points
9879
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
3answers
Olympus WS_100
Hi
Check any virus is their or not.
due to the virus the file can't open.
Using any anti virus try to clean it.
thank you
Am I able to recover erased file on Olympus WS100 digital voice recorder
Sorry NO...once files are deleted they are gone...there is no"recycle bin".
HOW TO FORMAT WS-100
Hello Press the FOLDER button to choose a folder
Press and hold ERASE button for 3 seconds or longer.
The ERASE indicator will flashes
Press the ERASE button again.
Done blinks for two seconds and the deletion will be complete
Note AN erased file cannot be restored.
During this process don’t remove batteries. Otherwise data may be damage
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
11helpful
2answers
Restoring disk on olympus ws 100
I reformat my olympus ws 100 on a mac and, erase everything, and the computer didnt want to recognized it. When turn on the display showed check and went off. When turn on without connecting to the computer and without the hold the display showed no format. If you use the foward button you can change the display to yes format and press play to select. That solve the problem.
Olympus W_S 100 can't record/erase
the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Is it possible to stop recording without opening a new file?
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
