To erase a message while it is playing, press the ON/OFF ERASE button. The
answering system announces, "Message Erased" to confirm the message has been
erased.
To Erase All Messages: When the answering system isn't playing or recording messages, press and hold
the ERASE button until you hear the "Messages Erased" announcement. Release the
button after the announcement. This feature allows you to erase all old messages
but not new messages. If you do not have any messages, the answering system
announces, "Zero Messages."
User Manual: http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
Hello unfortunately this unit don't have a erase function the only thing you can get a Microcassette eraser this eraser will help even if you decide to buy any micro or mini cassette transcriber when you used the erase function on the unit the life on the head, rewind, gears and motors get reduced by using this method if you used and eraser it erase the tape Magnets are on top and bottom eliminating the need to flip the tape allowing complete erasure on one second heare is a eraser you can buy and it is cheaper than buying other unit. http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
