SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
SOURCE: While sewing my presser foot would lift for no
The Viking Designer 1 has a presser foot sensor system in the head/needle bar area. I believe that you have some thread wrapped around a link in that area. Look closely in the area that the take-up lever is in and if you see a thread end, try to get a hold of it with tweezers and turn the handwheel backwards to see if it unwinds.
Good Luck
Testimonial: "THANKS!!"
