Mercedes E-class E320 E350 E500 E550 E63 Exterior Accessory Chrome Abs Molding Trim Kit 2003 2004 2005 2006 2007 2008 2009 Logo
Bobbie Hampton Posted on May 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What amp fuse for the AC and Heater blower for mercedes Benz e 500
I want to replace the fuse I need to know what the amp is in the fuse box
Nadamamasboy
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 46 Answers
  • Posted on May 25, 2015
Nadamamasboy
Expert
Level 2:
New Friend:
Cheetah:
Answers
46
Questions
Helped
9854
Points
142
From what I found it should be 40 amps. Is the original fuse missing? If not, replace with what is already there but it shouldn't be less than 30 amps as these motors draw quite a load.
2004 Mercedes Benz 500. Where is the radio fuse box located in it please?
Question edited for clarity.
Question moved to model category.
Mercedes are the only manufacturer to have 8 or 10 fuse boxes :>D Don't forget the radio is also connected and monitored by the BCM.
Mercedes-Benz CL-Class & S-Class (C215, W220
Fuse Box Diagrams https://fuse-box.info > mercedes-benz > mercedes-ben...
Here you will find fuse box diagrams of Mercedes-Benz CL500, CL600, CL55, CL63, CL65, S280, S320, S350, S400, S430, S500, S600, S55, S65 (1999, 2000, 2001 ...
Mercedes-Benz E-Class (W211; 2003-2009) fuses ...
Here you will find fuse box diagrams of Mercedes-Benz E200, E220, E230, E240, E270, E280, E300, E320, E350, E400, E420, E500, E550, E55, E63 2003, 2004, 2005, ...
Fuse box diagram Mercedes w220 and relay with ...
FuseAndRelay.com https://fuseandrelay.com > mercedes
In our article you will find a description of the fuses and relays Mercedes 220 with box diagrams, photo examples and their locations. We will note the ...
Engine compartment · ‎Box on the left side · ‎Box on the right side · ‎Additional box
I need to know the fuse location for heater/ac fan blower ml350 2014
this
Mercedes-Benz M-Class ML 350 lost the glove box guide, i covers fuels.
blower dead on HIGH????????????
cab or engine bay box./
or here is service manual
https://eautorepair.net/Marketing/Default.asp
2answers
Where is the heater fan relay located on 1990 mercedes 190e
If the heater is not working (fan is not turning), but you are able to press the climate control buttons to activate the AC and venting, then the relay (actually this is the ACC in the dash with the buttons, there is no separate relay that controls the AC/Heater fan) is not the problem. Check the fuse box in the right side engine compartment, then check the long 3A flat fuse located in a coverd case atop the the wheel well in front of the fuse box. If these are okay, the fan motor is the problem. If the motor needs to be replaced, you'll need to remove the front cowl under the windshield, and also the windshield wiper assembly. The motors usually bind after 20+ years and need to be replaced. Sometimes, they will bind, then work again. Sometimes they'll bind and blow the long fuse. The job takes about 2 hours and the motor is about $150-$250.
1helpful
How to replace ac heater blower motor
i need to know how to replace the blower motor on 300e mercedes ,please call me 718 835 2596 il greatly appreciate it
Heater doesn't blow air? my front windows roll down but my back windows dont. their electric.1988 mercedez 190
Blower is used for either AC or Heater demand. If it doesn't work in heater mode, but work in AC mode then it is a problem with the Climate Control. If it doesn't work in both cases, then check the fuse near the front fender on driver side ( It is not in the fuse box). If the fuse is good, then it is not necessary the blower is burnt, but the blower regulator is burnt. The Blower regulator is underneath of the blower. It can be accessed from the engine side under the wiper motor.
8helpful
My heater and AC blower has stopped working in my 91 merc 560 SEL
check fuse. It is outside of fuse box in a black plastic strip fuse holder by the brake booster.
AC N MY CAR
Brushes on the motor may be going bad. Blower motor is in engine compartment under wiper motor assembly. The blower motor regulator is under the blower motor. There is an A/C relay behind the fuse box under the screwed down cover.
for lack of motor speed its probably the brushes on the motor or the regulator. If no cold air your charge is probably to low to engage the compressor.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
