Model no. ELEFW328
SOURCE: Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
SOURCE: TV screen is black. Was working went black and now nothing.
you have a bad capacitor in the power board you will need a tech to change it the can shaped device will be puffed up on the top and the value is written on the side
