Question about Sony Office Equipment & Supplies
How do I connect my PS3 to my sony vpl ex7 projector?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
You'll need a down converter similar to this, http://www.amazon.com/PETHV-converter-3-5mm-Stereo-Converter/dp/B003O55U8K
Posted on Sep 25, 2015
6ya staff
SOURCE:
stilyou
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
Anonymous
SOURCE: vpl-es4 sony projector-frequency out of range
change the screen resolution to 600x800,and switch to other monitor by hitting fn+F6 key (Laptop).if the screen get black use alt+Ctrl+F3 to switch it on .
thanks
Hussam
Posted on Dec 15, 2008
ABRsvcs
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
Posted on Dec 23, 2009
Where will i get air filter foam/cloth
i am also looking for this answer, it looks like people try to make a quick buck on ebay selling this http://www.ebay.com/itm/NEW-PROJECTOR-AIR-FILTER-FOR-3M-Projector-FIT-FOR-3M-PROJEDTOR-AIR-FILTER-/180827230857?pt=US_Remote_Controls&hash=item2a1a249289
But im going to just go buy some thin foam type stuff and keep my old frame and glue or attach the new stuff to my old air filter frame and that should take care of it.
GOOD LUCK
Jun 12, 2013 | Sony VPL EX7 LCD projector 2000 ANSI...
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I got flikkring picture display with my sony vplex7 projetor
Try a different source ie a laptop and see what happens.This sounds like a source problem.
May 03, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I can't get marry my laptop to the projector the manual is lost. had to buy new usb cord and still can't get the projector to play my video
the projector needs a vga cable or composite connection to show the display from the laptop , it will not work with a usb lead
If you found this info useful please vote for me
vga to vga lead looks like this
a composite lead looks like this
Mar 30, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Hello, good day. My problem is relationship my sony xga vpl - ex7 not turn on. Only lighting the lamp/cover.
Either lamp is dead/ broken in projector or lamp cover is not fixed properly (its located at bottom side)
Please check lamp and replace it if its broken and make sure lamp cover is fixed back on its location securely after lamp replacement/ checking.
Thanks.
Jan 24, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
IC TOP247YN is blasted. from where can I buy it and how to solve the problem
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
When you have purchased a replacement IC de solder the old one and fit the new one.
Just Google the part name and follow the links.
I hope this helps.
Dec 26, 2010 | Sony VPL EX7 LCD projector 2000 ANSI...
Ps3 frequency out of range
This model will only support 1080i. What you need to do is go into the display settings on your PS3 and set the max resolution that your TV will support to "1080i" That should get you going!
May 19, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
193 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
