Camera powers on when connected to wall charger, and I am able to perform all functions as long as it's plugged into wall charger; takes pics, share, etc. I thought issues would be resolved since this is a brand new battery, but once it's unplugged from wall, it's as though the battery wasn't even charged.
SOURCE: Kodak DX6440 won't power up using batteries
There's a chance that the drop is irrelevant to your problem. You could try using a small eraser to clean the battery contacts down in the chamber (make sure to dump out any eraser particles) and try a new CRV-3 battery, which because of it's slightly longer body produces a little more pressure on the contacts. If that doesn't work to improve things then your cam might need a repair, your call there. Good luck
SOURCE: Kodak Easy Share DX 4530 won't hold charge any more.
Yes rechargeables need replacing from time to time (after a few hundred charges) or every couple of years.
You can use standard rechargeables but these wont charge on the dock as there is a little switch in the battery bay which the kodak pack presses.
Standard AAs ar'nt recommended for digital cameras but you should get at least a few shots from a new set of alkalines (maybe not if they are cheapo no Alkaline)
There could be another problem with the camera but if you like the camera its probably worth giving a new pack a try.
If I remember rightly (but check as I don't have a 4530 to hand) the battery you want is a KAA2HR and are available on ebay cheaply if you cant find a low cost one locally
If I can be of further help drop me a line
Best of luck
SOURCE: my camera worked perfectly fine until the battery
your battery area is infected with the chemicakl that is leaked from your old battery.
get it cleaned by an expert with chemical treatment.
also fornat your emory after cleaning
sagar
SOURCE: The camera doesn't open and it doesn't charge. It is dead.
I wonder if you attached the right voltage of charger.
Thats what I did. I put on a 9v dc charger
Now my v570 is dead......but ironically it will still charge a battery.
Now an expensive battery charger!
SOURCE: Is it the DX 4530 camera, dock or batteries that aren't working?
If the batt aren't KODAK there might be a problem.
I will suggest an alt. charger.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
