My Jura coffee machine do not switch on, there is not electric connection problems, simply is like ***** the switch on button do not respond, lately it was a big storm here and the electricity cut off.
SOURCE: Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
SOURCE: Jura impressa E75.message mafunction 8 shows up
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
SOURCE: Jura Capressa E9 Leaking
Most likely the 2 spouts have become plugged with crud. Use a toothpick while the machine is dispensing coffee. Stick the toothpick up in each little nozzle and move it around it might take several cups to get this done. I removed the top cover on mine and just poored water in where the coffee normally goes. It is just a gravity feed system. Don't poor too fast and move the toothpick around until the blockage is cleared. Helps to have 2 people for this. Also, once you get it cleared, try the finest grind setting. Mine was set on the coarsest setting and I think that was making making the blockage more likley. I dont think the cracked spout is common though. My machine has made over 8100 cups and is going on 7 years. No cracks are visible in mine.
Please dont forget to vote this answer was helpful
Many thanks
