SOURCE: Mower will shift into forward and reverse gears
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
SOURCE: JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
