Garden Logo
p
pete Posted on May 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace gas tank - Garden
mgbgene
Level 2:
Sergeant:
  • Expert 253 Answers
  • Posted on May 23, 2015
mgbgene
Expert
Level 2:
Sergeant:
Answers
253
Questions
Helped
59351
Points
560
You don't say what kind but just go online and type in your model and manufacturer. There will be a bunch of sites pop up
1helpful
2answers
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
1990 ford ranger gas tank straps replacement
Get new straps. Drain gas tank if possible, prop up gas tank from underneath, remove old straps, install new straps.
The mower is leaking gas badly right under the gas tank. would it be the acatual gas tank or the hoses or how is it best to locate the problem.
Take off the gas tank, empty it and with an air compresser, blow the air through where the hose was on, while covering the other hole with the palm of your hand. If it "pops out" theres no crack in the tank. Try replacing the hose. If you hear air blowing, replace gas tank.
Apr 11, 2010 • Garden
2answers
Says gas is empty but when at the pump its stops filling.some gas exits back from the tank, I figure its my pin any way to find out if im full or not?
What Pin? Your sending unit is most likely worn out,on a 19 year old vehicle. Pull gas tank and replace complete assy,fuel pump and all,while your there.
3helpful
2answers
Fuel leaks from filler pipe to gas tank
You don't need to replace the gas tank, the filler pipe is connected to a rubber hose which connects to the tank with clamps at each end.
1helpful
I have a 1989 Bronco 2 and it is not getting the fuel right. I think it is the fuel pump. Does anyone think what else it would be. I already replaced the filter. How would I replace the fuel pump?
The fuel pump is in the tank. Drop the gas tank.
1. Support the gas tank with a jack or something
2. unbolt the gas tank straps
3. unscrew the rubber filler neck going to gas tank
4. Lower gas tank slowly and disconnect gas lines
5. Turn the retainer ring that holds the fuel pump in the tank and left out.
6. Drain gas into gas cans to make the gas tank easier to left
7. Replace fuel pump and reinstall gas tank.
Original gas tank replaced because of holes. New
It sounds like the new gas tanks do not have a breather fitted to them.
As you remove gas from the tank it needs to be replaced with air if not it creates a vacuum and natures way of filling a vacuum it to compress the space it is in
Fill a plastic soda bottle with fairly hot water , give it a minute then pour the water out and quickly screw the top on , watch the effect , that is your gas tank
There is either a metal or rubber tube or even a vent in the filler cap to allow air in
You did something to alter that ?
Gas tank on a 2001 Camry with loose filler tube
Anything is possible, you could look to see if the fuel tank appears newer then the rest of the under body, however a new fuel tank is not such a bad thing, if it were installed properly...
Top Garden Experts
Jay Finke
Jay Finke
john h
