SOURCE: I have a LG Verizon 3.2 phone and I was having an
If the Disable option is showing but the Enable is not then either the Play Services is enabled or your thinks it is. This information is held in the phones cache memory. Clear the cache and then start again.If you need to know how to clear the cache then post another question please.
SOURCE: Please help me I'm obsessed with candy crush and I
With Google Play store sometimes updates don't go as planned when it updates the actual app that is used to download other items to your phone. Best way to fix this is to go to [Apps] --> [Settings] --> [Apps or Application Manager] Choose [All] from the tabs to choose. Then scroll down till you find [Google Play or Play Store] From here you can click on it and then choose "Uninstall Updates" after this is completed you should be able open play store again like normal, select Yes to the terms and conditions and then be back up and running again.
SOURCE: How do I download google play store?
It is there with a different name you are using an older version of android. it was called market I think. If you are on a different operating system try getting aps from that applications support system. accessible using a laptop.
SOURCE: read books through google play store
In settings, check display setting for brightness. See if the auto brightness is selected. If so de-select and try. Another thing to check is the battery saving mode !
Testimonial: "The app is a Google app, and Google told me to call Samsung, Samsung said they could not help me because we use Tracphone as our carrier ... wha? and told me to call Tracphone...you can guess the outcome of that...a second call to Samsung using a different 1-800 number WAS helpful. She told me how to get into Safe Mode. From there I deleted the recent UPDATE to Google's "Play Books" app. All is good now, the recent update is broken. Thanks for the suggestions anyway!"
