HP OfficeJet J4580 All-In-One Laser Printer Logo
J
JEAN JANES Posted on May 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam in printer
How do remove paper from a paper jam
broris holt
Level 1:
  • Contributor 20 Answers
  • Posted on Jul 03, 2020
broris holt
Contributor
Level 1:
Answers
20
Questions
0
Helped
20071
Points
91
The complete guide on paper jam in printers is available here, I hope this will solve your issue.
Source: https://printererrorstate.com/blog/hp-printer-paper-jam-error-solved/
Mike M
Level 3:
  • HP Master 3,349 Answers
  • Posted on May 24, 2015
 Mike M
HP Master
Level 3:
Answers
3349
Questions
0
Helped
686773
Points
16707
How do i remove the cover on the exit rollers to remove a jam
To remove a paper jam from the exit rollers of a printer, you'll typically need to access the jammed area by opening the printer's covers. Keep in mind that the process can vary depending on the printer model and brand. Here are general steps you can follow to remove the cover and access the exit rollers:
  1. Power Off the Printer: Before attempting to remove any jams or open the printer covers, make sure to turn off the printer and unplug it from the power source to avoid any risk of electrical shock.
  2. Open the Printer's Top Cover: Most printers have a top cover that can be easily lifted to access the internal components. Look for a latch or release button on the printer's top cover and gently lift it up to open.
  3. Locate the Jammed Paper: Once the top cover is open, carefully inspect the printer's internal area, especially around the exit rollers, for any visible jammed paper. If you find the jammed paper, gently grasp it and pull it out in the direction of paper movement to avoid damaging the printer.
  4. Check the Rear Cover (if applicable): Some printers have a rear cover or panel that allows access to the exit rollers and other internal components. If your printer has a rear cover, you may need to open it to clear the jam completely.
  5. Remove Paper Trays (if necessary): If the jammed paper extends into the paper trays, you may need to remove the trays to access and remove the jam more effectively.
  6. Clear Paper Path: Ensure that all remnants of the jammed paper are cleared from the printer's paper path. Check for any small pieces of paper that may have torn during the jam and remove them as well.
  7. Close the Covers: After you have successfully removed the jam, close all the printer covers securely. Make sure they are properly latched to ensure the printer functions correctly.
  8. Power On the Printer: Plug the printer back into the power source and turn it on. Perform a test print to verify that the paper jam issue has been resolved.
tip
How to repair paper jams
<span>Instructions</span> <ol> <li> Turn off the printer. As the printer shuts down, it will automatically attempt to remove any paper that is jammed.<br /> </li> <li> Pull any paper that is visibly sticking out of the printer. This can help to remove it if the paper is loose enough.<br /> </li> <li> Open the printer as you would to change the ink cartridges. Check inside to see if you can find the jammed paper and gently pull it out. You may need to remove the ink cartridges. Alternately, some desktop printers have a separate panel at the back of the printer that you can take off in order to remove jammed paper from the roller.<br /> </li> <li> Turn the printer back on and repeat the steps if necessary.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Gently pull any jammed paper using both hands and avoid ripping. Tearing the paper may worsen the jam.</li> <li> Avoid filling paper trays to maximum capacity in order to prevent printer jams and never use damp paper.</li></ul>
My printer chew one side of paper laserjet 1320
Is the correct model number: HP Deskjet D1320 Printer ? Was printer working properly at one point? May be resulting from failure to fully clear a paper jam:
Paper jam
To clear a paper jam
1. Remove the paper from the paper tray.
2. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
3. Turn off the printer.
4. Remove the rear access door. Press the handle to the right, and then pull out the door.
5. Remove the paper jam from the back of the printer, and then replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Caution Remove the paper jam carefully as it is possible to damage the printer when removing paper from the front.
7. Reload paper in the paper tray.
8. Turn on the printer.
9. Reprint the document
if this does not help I would suggest installing a new driver from: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ca&docname=c00211293&product=1839853&
Trust this is helpful. :)
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
1helpful
Paper jam how to repair
In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
3helpful
Paper jam in hp1300 cannot print
Remove the cartridge and paper tray to see where the paper jam is. If it is a whole page jammed inside of printer, before removing shut off printer and carefully remove paper if you end up tearing a piece this will make it harder to remove in pieces. After you have removed jammed paper reinstall toner cartridge and paper tray turn printer on and see if this clears the jam error message.
4helpful
2answers
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
2answers
Paper jam error
Open the access door, move the carriage if necessary, and then remove any jammed paper. On some Laserjet printers, you might need to remove the toner cartridge and/or imaging drum to access the paper jam. If your printer has a paper path cover behind the carriage, remove the cover, and then remove any jammed paper
Regards,
Will
2answers
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
k24674
Grand Canyon Tech
Grand Canyon Tech
