Rear seat cushion-fold forwards,release plastic clip from hinge,remove wiring multiplug if applicable.Lift out cushion.(40% backrest)Tilt forward approx 20degrees,use a screwdriver to release catch retainer on outer pivot pin.lift backrest and withdraw from inner pivot pin.Lift the backrest from inside vehicle.(will only lift out if backrest is tilted forward 20degrees from verticle. 60% section can then be removed on saloons by releasing the lock with a finger and pulling from the anchor pins.On estates unscrew centre seat belt lower mounting and unscrew hinge pin from centre support. unhook upholstery clip and lift backrest from lefthand side mounting.slide backrest towards the door to release centre pinlug and withdraw backrest from inside the vehicle. Refit in reverse order.
Fig. Typical W-Body rear seat cushion removal
Fig. Typical W-Body rear seat back removal
