Hi Bello,
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
SOURCE: sharp lc-37sb24u. Flashing Green Light
Backlight invertor is most likely cause of the problem, in rare occasions defective CCFL lamps could cause similar symptoms. Replace defective parts, reset lamp error counter and you good to go.
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
