SOURCE: sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
SOURCE: Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
SOURCE: have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
SOURCE: my sunbeam mixmaster (50 Years old)model 12c 150
Try one of these small appliance repair shops:
http://www.fixya.com/repair/small_appliances/us/ca/winnetka
SOURCE: My Sunbeam Heritage MixMaster mixer just stopped
If it is plugged into a circuit protected by a GFCI breaker, which it should be if it is a kitchen circuit, reset the breaker. If you know for sure there is power at the receptacle you have it plugged into, then the power cord is bad or you have an internal mixer problem. You will have to pay someone to repair it or take the mixer apart yourself and find out what is wrong. Before paying someone be sure and get an estimate as to the cost of the repair. In some cases you are better off buying an new mixer as the repair costs will exceed to price of a new one.
