Sewing Machines Logo
j
jeremy windrider Posted on May 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why isbobbin stitch on top weird how do i fix
When trying to sew zig zag bobbin stitch comes out on top
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on May 24, 2015
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2615594
Points
59176
If the bobbin thread is pulling through to the top of your fabric, your needle thread tension is too tight. Loosen the top tension until the needle and bobbin threads meet in the middle of the fabric.
My needle goes side to side but the stitches are straight stitches on a brother sewing machine
So your set up to sew zig/zag and only get the zig or the zag : )
Could be top thread tension is too high. Switch to a straight stitch and reduce tension until top thread starts to appear on bottom. Then go back to zig/zag and see if it sews properly.
If still dropping stitches, check the needle is not bent and is fully inserted into the holder. Clean the bobbin, hook, and race per machine instructions. Try reducing the stitch width and see if that makes any difference. If still not right then timing may be off.
When I use a zig zag stitch ESPECIALLY on stretchy fabric it pulls the fabric together. Also when I sew zig zag the bottom part of the stitch looks like little y's instead of a proper zig zag.
It sounds like maybe the bobbin tension is too tight. It is pulling the top thread down to the bottom of the fabric. If you tighten the top tension it causes the fabric to pucker. If you loosen the top tension, more of the top thread will show on the bottom. Correct tension is when the top and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension on Your Sewing Machine
My Memorycraft 6600 zig-zag stitch is not working. The fabric would not advance and the needle comes down ******* the metal if I try to shorten the width of the stitch.
suggestions
if the zig zag stitch is not working could be something wrong with the cam
try taking the bobbin out & use a different bobbin
try a new needle, make sure the needle is correct for the fabric being sewed
could also be a problem with the feeddogs
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
2answers
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
3helpful
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
2answers
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
