Question about La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor
Have two la crosse clocks, one outside temperature stopped working, I changed to batteries in the temperature system and both clocks stopped outside temperature readings.
SOURCE:
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
homedesigner
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
BillB-SA
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: how to reset la crosse wall clock
It sets itself. You choose the time zone.
watch the video.
http://www.klockit.com/products/dept-52__sku-87109.html
Downoad a typical manual.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Posted on Feb 22, 2011
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 | Home
How do I get a new outside temperature sensor?
You may have to order a replacement sensor directly from La Crosse.
Apr 29, 2015 | La Crosse Technology Lacrosse Technology...
Do you have to change batteries on clock inside house along with outside batteries to get correct outside temperature
My most consistent (best, repeatable) results with this process are to replace both sets of batteries, both in the clock and in the outside temperature sensing unit. Start by removing all batteries out of everything. Now replace the batteries in the outdoor unit, then (within 30 seconds) replace the clock batteries. The temp unit should begin communicating normally within 5 minutes (or less) and yes, you will have to reset the clock,
Nov 01, 2014 | Lacrosse La Crosse Technology Wt-5220u-it...
Even with brand new batteries inserted into the Reciever, I still can't get an outdoor temperature. Why ?
Make sure they are both set to the same channel (normally channel 1) put them next to each other then press reset on the temperature unit only.
www.serendipity-gifts.co.uk
Jun 19, 2012 | La Crosse Radio Controlled Atomic Clock
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Jan 08, 2011 | La Crosse Measuring Tools & Sensors
Outside temp. display
if it is wireless then check the sender unit
check the battery
severe cold weather can be hard on batteries
Jan 02, 2010 | La Crosse Technology WT-2171-UCS Digital...
Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Aug 02, 2009 | La Crosse Projection Alarm Clock with...
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
Jan 25, 2008 | La Crosse Technology WS-8001-UM Digital...
La Crosse Technology TX37UIT 915MHz Wireless Temperature Sensor Logo
259 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
