Panasonic KX-T7636W Corded Phone Logo
A
Anonymous Posted on May 21, 2015
Phone diversion wont turn off?
I've somehow turned on a diversion to an offsite external phone, and cannot turn it off, how can i disable the call diversion (doesn't go through the phone, diverts automatically) FWD and DND is disabled and the originally programmed number has been removed. Yet it still calls through to the external number.
John mullen
Level 3:
Master:
  • Master 296 Answers
  • Posted on May 21, 2015
John mullen
Master
Level 3:
Master:
Answers
296
Questions
0
Helped
75963
Points
1130
Can't you just contact your systems admin? :)
Are you sure you turned off the call forwarding?
http://service.us.panasonic.com/OPERMANPDF/KXTVA50.pdf
No Dial Tone from BT Diverse 7110 Single
Check that the volume on the handset is turned up, also replace the batteries or put in non-rechargeable ones to get the phone working at full capacity. If bought from Amazon you should be guaranteed for a year, not a month!
2answers
How do i turn my voice mail off on orange network?
Usually when you call your voicemail number there is a voice menu that gives access to settings, where you can configure the voicemail and turn it off as well.
If you have trouble with the above, you can also leave the voicemail available, but prevent the network from redirecting calls to it when no answer/not available.
For that you'll have to browse your phone's menu and find "Call Diversion" in your phone's connection settings, and turn off all 3 diversions: on no reply, on not available and on busy.
Hope to have helped.
Jul 22, 2011 • Cell Phones
I want to turn off the answering service on this telephone
Not sure what you are talking about here - if you mean an answering service (like an actual receptionist offsite answering your telephone calls) then you need to take your phone off of call forwarding with the string *73 & listen for the phone to have a stuttered tone. Thats it!
1helpful
Screen says battery is required to charge powering off
I was having the exact same problem and figured the battery or phone was hopeless because I've seen so many negative comments and no solutions. BUT, I kept messing with it and eventually I removed the battery and plugged the charger into the phone WHILE THE BATTERY WAS STILL OUT. Once I put the battery in with current already flowing, somehow, the phone started right up and started charging normally. Not sure if it'll work for every phone but somehow that did the trick for me and I've been messing around with my phone all day with no luck.
My phone won't turn on after i lock it.???
On some phones, the lock switch or key disables ALL the buttons, therefore even the on off button will be disabled. unlock it, turn it on, then lock it again.
If your saying that you removed the simlock from the phone and now it wont turn on, then you have unlocked it incorrectly and the phone is only fit for the trash
My i9+++ phone wont turn on
HI,
problem can be solved. How long has it been in the box and when last did you charge the battery of the phone?.
The longer you keep a phone and don't use it, it is likely to affect the phone somehow.
The battery has not been charged for a long period of time and the cell of the battery is weak, that's why the phone is not coming.
You need to charge the battery for longer hour for it to regain the strength to power the phone on again. After longer hours charging of the battery, the phone will come .
Have a pleasant day.
2helpful
Taking off Do Not Disturb
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Tty
Try disabeling TTY unless you need it it (it is a hearing impaired function). To disable do the following: In idle mode press the Menu soft key to access menu mode,
Select Settings and highlight Phone Settings,
Press the Select soft key or the Cingular key,
pres the 5 key and highlight the Disable selection,
Key in the password: 4889,
Press the OK soft key
For additional technical support call 888-987-4357
3answers
Ringer turns off when I don't want it to!
To the best of my knowledge there is no way to disable the feature...Sorry...
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
