ZEEPAD 7DRK Dual Core 4.2 Blue Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 BLU Logo
Lori DeBusk Posted on May 21, 2015
How to get memory card to work - ZEEPAD 7DRK Dual Core 4.2 Blue Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 BLU
1helpful
Internal memory running out despite internal SD card nearly empty.
You might try reformatting the SD card with a card reader connected to your PC. Also, your tablet has it's own memory limit, if you are saving stuff on the tablet memory instead of the external memory card you might be pushing into the tablet's limits. Get a handle of your memory limits by downloading ES File Explorer if you have an Android tablet to navigate internal and external memory.
Can't download games error window says not enough storage. Bought 16 mg memory card not working
Probably you get the error because, by default, all downloads go to the internal storage, not the memory card. Make some room on your device by moving pictures, videos, songs to the memory card. You can also move some applications to the memory card using the Application Manager feature of any Android device.
How do I add a memory card to the Supersonic SC-89BL?
I don't think your tablet has a slot to add a memory card. Please check the user's manual; I might be wrong. If you can install a memory card in it, the user's manual will show where the memory card slot is located and how to install the card.
How I get my memory card on Acer tablet to wok. All that space can't download anything
Your new memory card won't "free up space" until you move stuff from the internal memory to the new card. You can do this with the file manager. The new memory card will show as an alternate location you can move stuff to.
How do I move memory in my Nextbook 8se premium around to better manage it?
As far as i know this meathod usually works with apps. First you go to settings, second you go to storage, third you go to something like apps, fourth you select an app, fifth you select move to SD card or move to internal memory depending on where you have your data saved. I hope this helps anyone with this problem, im no expert but i will try my best to help
I mean stuck on android start up
Here are some steps you can take that can get you past this point.
1) Remove the battery and memory card from the device.
2) Reinsert the memory card and attempt to start the device.
3) Insert the memory card back into the phone and restart the device
Note: if this does not work you may have to resort to steps that require knowledge in basic computing
4)
Format the memory card
5) Wipe the cache partition of the memory card to clear all of the used system memory.
Will my android work without the memory card
Most Android tablets will work without a memory card.
2helpful
Will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
9helpful
4answers
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
