A genuine Cartier ring will be stamped on the back with Cartier's logo, the jewelry's metal type (Au 750 or 750 for 18k gold or Pt 950 or 950 for platinum), the ring size in mm, and a unique serial number. The stamp should be evenly spaced and, of course, free of any spelling mistakes.
Most of the time you can find the serial and or model number on the first link that is attached to the case of the watch on the back. Often there is a serial number on the back of the case itself. If not in any of these locations you may have to open the case and look on the inside of the case. Be careful with opening case, if you're not comfortable opening the case yourself take it to a reputable jeweler. If there are no serials on the watch it is probably a knockoff or replica.
mcdevito75 here, I just took a peak into my own Older Timex watch, even though it"s a ladies the model number was on the movement itself and only a 3 digit number. Since the older Timex watches were mass produced this is all you may have as far as serial numbers go, and Timex did all their own watches so a serial number may only be 3--4--5 digits long. Anyway, double check the entire watch with a magnifier glass for the serial number, then check inside the back cover and movement itself. Here is Timex contact info, 800-448-4639 if needed.
mcdevito75 Here, Hello Rani, Piaget, a FINE watch, even without seeing your Piaget watch were speaking $250.00 and above. Shop a couple of jewelery shops in your area, they will be glad to help. NOTE-- unless you relly know, DO NOT CLEAN THAT PIAGET YOURSELF as any Damage could and would leesen it"s value. By cleaning I mean even polishing the band, have a small watch repair shop in your area care for your Piaget watch.
once the circuit is cut the watch stops and leaves ur 2 options. o
1 replace
2 the make a circuit glue which coats the whole circuit and most cases restores power, this is very inexpensive. they dont recommend cause they want to sell parts
