KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Eric Bawden Posted on May 20, 2015
How do I replace the door handle on my KitchenAid microwave?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 25, 2008
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Anonymous
  • 460 Answers
  • Posted on Nov 17, 2009
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
Anonymous
  • 5911 Answers
  • Posted on Dec 14, 2009
SOURCE: how to replace the door handle
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Anonymous
  • 6784 Answers
  • Posted on Dec 22, 2009
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Replace door handle kitchenaid microwave KHMS155L
khms155l-sdpzxnx2wca25pymlghkdstt-2-0.jpg Here's a diagram of the door. On the inside of the door is the frame, #2. This can be removed very carefully with a small flat bladed screwdriver and work slowly around. The frame is held in place with plastic tabs on frame. Once frame is removed, you should see the two screws that hold the handle in place. Good Luck!
How do I replace kitchenaid microwave door handle?
This is not a fun one if you take a putty knife and go in between the outer door and frame you can release the outer door cover hears the catch over time the door frame becomes brittle so there is a 50/50 chance the frame will break trying to separate it
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
How do I get the door handle off for replacement?
if the handle is available separately; it's more than likely screwed in from the inside of door. carefully remove the inner door trim with a small putty knife; working it around. screws for handle should be visible.
1helpful
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
Need installation instructions for replacing door handle on kitchenAid microwave oven model KHMSi55LSS0
Remov fan cover, bottom plate, you can either do it right and pull out the entire plastic baffle to reveal the hindge bolts or you can just jam something between just enough to get a long socket on a small socket wrench. You must replace the entire door. Trying to replace just handle is almost impossible.
1helpful
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
