Has bad (open) thermostat 36tMH01 L156-15c. Sears does not carry parts for this coffee maker. thermostat is open numbers on thermostat are 36tMH01 L156-15c, also has 561782 and S1311, If I knew the cut-off temperature I could probably find a replacement. This coffee maker makes great coffee and a lot of the flavor is due to the water temperature.
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
SOURCE: Door Handle
Yep, if the engineer had worked for me, I would have fired him/her. I have gone through 3 of them of the past 3-1/2 years until I got tired of it.
That said, it likely brakes at the same corner/corner. You will likely find a cavity inside each broken half. Using superglue and a small flat piece of metal (cut from a metal washer) sized/formed to fit inside cavities when the broken half are pieced together. Trial piecing the pieces together first before glueing them together.
If there are no cavities (solid), try creating one (you may be able to drill/carve out) in each broken half then follow the steps above.
Guaranty better than new and last a whale of a lot longr.
Good luck.
SOURCE: I would like to purchase a Kenmore elite steam
Sorry to read about your problem, I hope this helps you out.
In my modest humble opinion, run as fast as you can and stay away from them. you are better off with a rock, at the river
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Testimonial: "Very helpfull thank you"
SOURCE: INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
