Why is my light showing a very dim blue, and I can connect to my mobile devices but not my desktop. This all happened after a lightning storm and power outage
The control board to your range may have been damaged because of the lightning storm. It happens when lightning strikes a power line and sends a surge of power to your home. This large current surge can easily damage electronic circuits. More often than not if a device is on and lightning strikes, that is when the device gets damaged. During large lightning storms it is best to turn off all electronic devices. The electricity going to your house is fine now and that is probably what your electrician checked.
IT COULD BE THE POWER SUPPLY GOT SHOT OR THE TUNER DEPENDING ON THE CONNECTION WHEN IT WAS IN USE .SOME TIMES THE TUNER GOT SHOT WHEN THE SET IS CONNECT WITH THE COAX CABLE LIGHTNING WILL SURGE THROUGH THE CABLE IF IT IS NOT GROUNDED PROPERLY ...GOOD LUCK
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
If these problems started immediately after a lightning storm, the printed circuit board is probably damaged. Contact a garage door service company (check the phonebook) for diagnostic support.
If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device
If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre.
You might have had a power surge.Try unplugging your TV for 5 minutes and plugging it back in. If you cannot get a picture from any device such as a DVD player and cable then your TV needs serviced call a repair man. Good Luck!
Probably fried the 10 ohm resistor in the device. Anytime you are connected to a phone line (or DSL) and there is a storm, there is the possibility that it will fry (destroy) the resistor that is put in your device as a fuse to keep from destroying the whole device and causing a fire. Unfortunately, in today's devices this is a surface mount resistor and is not replaceable by the general public. Your solution is to buy a new device OR open it up and replace the 10 ohm resistor (it will be where the large brown spot and funny smell comes from).
This is why they have phone line protection on most of the newer protective power strips. Could have prevented this from happening.
