I was making 50 copies of a document and now it makes a grinding noise no matter how many copies I want to make.
SOURCE: Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
SOURCE: MP620 making grinding noises
check any paper jam inside the printer
clean compleatly using one brush
SOURCE: Canon mf6530 crumples paper and makes grinding
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Testimonial: "Great suggestion But need to know where the "fixer" is? I downloaded a service manual but I am use to fixing computers."
