Try adding between a teaspoon to a heaping tablespoon of Baking Soda or Washing Soda to your dish washer soap.. Both seem to work. Baking Soda is actually food grade if that worries you. Not supposed to eat Tide pods and people use them in dishwashers. lol. So I have also used Arm and Hammer washing soda. This is also dirt cheap compared to things like Jet Dry. It not only softens the water it also knocks foaming or suddsing way down. I use a small amount of Dawn or Cascade and some Baking Soda and glasses come out crystal clear. Use dish soap at own risk. It WILL make a huge foamy mess without Baking Soda or if you get the ratio off too much. Before I tried this my dishes came out covered in horrible white spots so bad I had to hand wash them and the spots were stubborn.
I found this on ehow I believe it will help.
How to Troubleshoot Dishwasher Residue
By Dale Yalanovsky
eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
Hard-Water Residue
Greasy Residue
Streaking and Spotting Residue
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
I have tried the rinse agent without any improvement and the water is plenty hot enough. That leaves the dishwasher detergent which I had not changed when the problem started. It is almost as if the detergent compartment doesn't open fully limiting its ability to aide in the cleaning and then leaves residue. Any other thoughts?
In the past we have had food get stuck in the jets of the sprayers.( kids not rinsing plates). If that happens the sprayers will not shoot out enough water and may not spin.
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
heatman101
