Dryers Logo
Posted on May 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does it mean when there's an hour glass on the display? It stopped running last night and there's an hour glass?
Gregg
Level 3:
Master:
  • Master 362 Answers
  • Posted on May 19, 2015
Gregg
Master
Level 3:
Master:
Answers
362
Questions
0
Helped
91471
Points
1014
It means ''wait'' (seriously).
The question is: ''why is it displaying that message?''
If it is _still_ displaying that message. Try unplugging it for 24 hours.
If after that it _still_ displays that message, you may have a bad computer board.
Having issues with my true GMD-41SL-54, fans blower is running but unit has stopped cooling. It stays a little over room temp but fans keep running. It started 2 days ago all of a sudden. It was working...
You have lost gas (hissing), you need a refrigeration engineer
GDM-41SL-54-HC-LD - Retail & Display ' True Manufacturing ...
www.truemfg.com > Glass-Door-Merchandisers > GDM...
GDM-41SL-54-HC-LD. Glass Door Merchandiser. Compare. Description, Product Specs, Files & Downloads, Product Video. The world's #1 manufacturer of ...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door ...
www.nellaonline.com > products > true-gdm-41sl-54-h...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door Merchandiser is designed with the highest quaity material ensuring long-lasting durability. The LED lighting ...
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
1helpful
2answers
It only last for 1 hour and a half . according to the store this is normal because my processor is AMD athlon and 2 gig memory. i thought 6 cell batteries run for abt 3 hours. is there a compatible battery...
The lithium iron battery for this conputer is 4000 mA/hrs. or 4 Ampere hours. That means that with a draw of 1 Ampere the computer would be useable off the battery for 4 hours. Since you can't run off the battery below a certain voltage you can deduct 20% leaving a battery life of a little over three hours.
1helpful
DVB8800HDhas stopped working
Our Celestial set top box has been fine for a year or so but jjust stopped last night. I can turn it on or off but it no longer displays a channel number or menu details. Any ideas, or is it dead?
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Hour glass on screen
the hour glass means its loading and u can stop it
3helpful
2answers
Netar MA933A
hour glass will not come on
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
2helpful
My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Top Dryers Experts
john h
