Suspect it is only using low heat. Selector switch seem ok. Reg. cycle thermostat tests 0 ohms at room temp. Low temp therm., Cool down therm, and hi-limit therm switch also test 0 ohms at room temp. Suspect reg. cycle therm. is opening at too low temp. and leaving temp control to low cycle therm. Is this likely? Is there any easy way to test? I have checked for airflow problems and fan is running normally. Should I order a new 3-03391 Reg. Cycle Thermostat? Thanks for help. Dave Hanna Georgetown TX
SOURCE: i have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
SOURCE: clothes take long to dry
Replace all of the t-stats first, they actually weaken over time. Cheap fix.
SOURCE: Whirlpool gas dryer model WGD9200SQ0,
Hello
& Welcome to FixYa The
problem is with the door switch or the flame sensor that is bad and needs
replacement, you can test both these parts and let me know the result. Please
get back to me if you have any other questions. Kevin
