Televison & Video Logo
Keith Gish Posted on May 17, 2015
For HL-T5087SA DLP I have lost all inputs to tv. Can't turn off or on with main control in center. All remote functions do not function.
Can only turn on or off by unplugging. No control buttons on side of tv work. Volume control image stuck on screen image. Screen image is ok.
Roland Archambeau
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 15 Answers
  • Posted on May 26, 2015
Roland Archambeau
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
15
Questions
Helped
5781
Points
34
Is there a reset button on the tv? on some electronice devices, if you hold down the power button for about 15 seconds, the unit will reset.
Can not get TV to turn on
It sounds that the main power regulator board to your TV has damaged. Contact any service technician.
tip
Lost Remote Control? Here's a way to help.
So you have lost, or, your remote doesn't work? You can't "Do anything" without it.... Right.... NO Wrong... ALL TV sets have a number, usually about 5 - 6, "Buttons" on the side, front, somewhere. usually close to the "Power ON" switch. Now these "Buttons" will perform nearly all, if not all, of the main functions of your "Remote" They WILL be marked, MENU, +, -, <, >, & OK or ENTER. Now you simply have to depress each button to access the "Functions" you want. One button WILL control the "Function" say Channel, and the <, >, will Go UP & DOWN. This is the same for everything. So one button will make it, say go UP, another will make it,say, go DOWN. Repeated presses on the "Function" Button will scroll through the "Functions" IE: Channel, Brightness/Contrast, Selecting Inputs, once "Selected" another "Button" will move the "Selector" through to the Bottom & another will scroll it back Up, sometimes the ONE button will simply continuously scroll "right around" Of course have a look in your manual... you know that paper thing you shoved away in the cupboard... This will explain it all. ALL TV's and devices that use a "Remote" are ALWAYS able to "Control" the MAIN functions of the unit,via keys on the actual unit itself. So don't despair, just spend a bit of time learning your "Buttons" that way even if the "Remote" does go walkabout, or the batteries go flat, or it just stops working.. well now you can still have complete control.. the only draw back is you will have to get put of your seat to do it. A small price to pay?
on Feb 13, 2010 • Televison & Video
tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
Samsung dlp model HL-T5087SA has audio but no picture
Check the bulb. If bulb is OK, check the Ballast board.
2helpful
I have a Samsung HL-T5087SA DLP TV and it keeps saying "Check Fan #1" and after a few minutes the TV goes off. Do you know how to fix it?
Well I suppose the first thing to do is see that FAN#1 is actually doing the job! If not then replace it.
If it;s turning off then there is a rise in temperature that is causing t6he sail safe sensor to sw2itch off to protect against further damage or even fire
Please rate my help++++Thanks for using FIXYA
tip
Input Switching Issues with Harmony and Samsung TV's
LCD
Plasma
DLP
LCD
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
OFF and ON
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
1helpful
2answers
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
