If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
With light switch on, test the wires leading up to the mentioned lights with a test light(cost about 5 or 6 bucks at wal-mart) that way u can eliminate any corrosion questions and get to the source quicker, if test light indicates that the wire is hot, than check connection areas for any wear and tear and possible carbon corrosion. Check lightbulbs, my license plate light stopped working and wire was hot, but wouldnt turn on due to the housing base, got too dryrotted and wouldnt function propery, had to rig it up, but works now.
You need to check components again when the engine is hot and in no-start condition, otherwise, you will get bad info...obviously whichever part is doing this works fine cold. ones that react most to heat are crank pickup, ignition coil and the fuel pump.(bad ones get hot and bind up)
If the hot plate is tilted then it should be able to be pushed back down until it is completely level. If not then it is damaged. Check to see that it is screwed in properly underneath.
