Usually the printers have only one USB port. If you had broke it, then it can be replaced (if mainboard is NOT DAMAGED). USB port is very cheep but you will need tools and skills to replace it. There is only USB input port(from flash memory stick) in front of the printer
good luck
pifonski
I had the same problem and I solved it. Slip off the black case and replace the part thats broken. its cheap. $10 here is the link: http://www.centrix-intl.com/details.asp?productid=9501 I HOPE THIS HELPS!!!!
There is no real fix for this other than trying to bend them back. Has this happened to all USB ports? There are 2 on the front & 1 on the back of the 360.
If not, use a USB hub on one of them to make up for the broken port. Not much else you can do other than take it back to the shop you got it from or contact microsoft to see if they will repair it though it will likely cost a lot.
Go to nokia center. I broke my USB port too. I told the staff at nokia care and they agreed to fix it since my phone is still in warranty. I told them i accidentaly broki it and they said they will log it as factory defect. Nice :) I got it back now and they cahnged the entire board.
I just found the same program with the same cables. I am going to try a usb to midi cable made by m-audio only because I have it hooked up right now to laptop running xp and the old version of Mircacle Piano which is the best by far and it works great. It is an M-Audio usb to midi cable called the UNO or something like that. its the one for 39 bucks very simple. It should work as long as your computer is running windows OS thats compatable or try running in 95 mode. Also some of these programs recognize processor speed and dont work on the newer systems. Good luck with it. have you ever used seen this software before? Ever see Miracle Piano? wondering how they compare.
Have to be taken to either your local PC repair shop or sent back to the manufacturer. I would send it back to the manufacturer because they are more familiar with your system. There is nothing you can do to fix it has to be fixed on motherboard.
Simple. Just solved it with advice from this site. If you see any of the gold prongs touching the side (or possibly each other) then find a thing tool and try to hook the gold prongs so they point direct upwards. how bad they get bent doesnt matter, just get them all standing up and not touching the sides. you probably cant use the port again but atleast it turns on.
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Buy a portable card reader. Insert in USB port. Insert your card and download. You don't need a cable then.I just bought one for $10.49 with a $6 rebate from Radio Shack.
