The non-turbo 2.2 Liter engine? 6 Degrees. Should be on your Emissions label under the hood.
(Firing Order is 1-3-4-2. Front of the vehicle is Number 1 spark plug. Distributor rotation is -> Counterclockwise. Spark plug gap is .044 44 thousandths of an inch)
Turbo 2.2 Liter engine? 9 Degrees. Emissions label is under hood.
(Firing Order is 1-3-4-2 Front of vehicle is Number 1 spark plug. Distributor rotates ->Counterclockwise. Spark plug gap is .044)
There is an in tank fuel screen where the fuel feed line screws into the bottom of the fuel tank. The is also a convertional fuel filter which is located just in front of the rear wheel on left or right side depending on model. I have a wagon and mine is on the right side. There is a plastic panel that you need to remove with a 10mm socket and a long extention. There are three screws to remove before you can get to the fuel pump/fuel filter area.
hi,seem you accidentally touch abs sensor,specially,if the wire of sensor have trances of crank,or clean your sensor maybe helpul,also the connection should connected,ty
