Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860. Why is it stuck in superwash mode?
The fast wash programmes either 60 or 30 mins has started showing the superwash (cloudlike) symbol for the 60 min wash or the acylics symbol when I select the 30 min fast wash. This means that the washer is taking 2 hours plus to do what is usually a 60 min wash. Any suggestions on how to reset this please? thanks
SOURCE:
  • 1294 Answers
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
  • 1294 Answers
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 02, 2007
SOURCE: Hotpoint WD129 Wash programme stuck
The solution was correct it was the heating element, after it was replaced the machine now works fine !!!!
Thanks for the help !!
Posted on Dec 22, 2007
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
  • 6 Answers
SOURCE: Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Posted on Oct 17, 2009
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Every time we try to wash it comes up test and goes through a test cycle. Will not wash. Hotpoint WF860
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Nov 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant get out of demo mode
press and hold both the On/Off button and the Start/Reset button until "D off" is illuminated in the display you should then be able to select wash programme as normal
Apr 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
WASHING MACHINE
Turn machine off and unplug for at least ten seconds
Then plug in and retry - according to Hotpoint that should solve problem
Mar 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
its possable not pumping out water when it should, is it???
Nov 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
