Car Audio & Video Logo
A
Anonymous Posted on May 16, 2015
Can you send me the link on what every Insert on the back of a JBL BP 1200.1 / 1200 watt amp is/ means? I've looked online and seem to only get URL's that are invalid. Thanks
5 Related Answers
Anonymous
  • Posted on Jul 12, 2009
SOURCE: jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Anonymous
  • 55 Answers
  • Posted on Aug 26, 2009
SOURCE: How to wire a sony 1200 watt amp
I believe what your trying to do is to run 2 12" subs and some other satillite speakers? We used to do that all the time.. That is called running the amp in "mixed mono" that's where the mids & tweets are run in stereo while the subs are bridged mono. This configuration is what made Rockford Fosgate "The Bomb" back in the day. To do what you want your subs have got to be 8 ohms, NOT 4, Dual Voice Coil 4 ohms would be OK. Before i tell you how it can be done let me tell you what will happen... For one thing you will be "making" your own cross overs for the subs and mids and tweets. Forget about using the cross overs on the amp. 2ndly you will lose about 1/3 to 1/2 of the amps power because the crossovers are so inefficient, so don't even think your going to get anywhere near 1200 watts from the amp. More like 300, and that's on a good day. But if you still want to do it you go to your Radio Shack and get 1ea 6.0 mHy (milhenry) coil and two 47 mfd (microfared) capacitors, or something close to that value. So you would wire your mids & tweets normal in stereo and on the + line to each mid wire in the 47 mfd capacitor. That is your h/p crossover which will crossover your mids @ appx 130hz. Now on your subs. You want to wire them in parellel (both +s twisted together and both -s twisted together so it looks like there is just one woofer with a + and a -) Than from the L+ of the amp run a wire to the coil and from the coil to the + of the woofers, than using the R- of the amp to the -s of the woofers. Do not use any of the amps built in crossovers leave it on full. Good luck. Mark @ Sounds Good to Me Tempe, AZ
Anonymous
  • 11 Answers
  • Posted on Sep 06, 2009
SOURCE: how well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Anonymous
  • 676 Answers
  • Posted on Nov 17, 2009
SOURCE: how i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Anonymous
  • 16 Answers
  • Posted on Mar 10, 2010
SOURCE: how to bridge a amp brutus hifonics 1200 watt
use the first - and the last + should run at 2 ohm then
Interested in your Infinity sub repair; could I send you some images to verify infinity TSS-1100 has no light, seems blown to me, not sure if it has the screw you mentioned
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P - you will find us ... Edwards Electronics ....
The ampe i got is the bp1200.1 is that 1200 watts in to one chanel can you tell me thanks
it is a mono (one channel) amp. it outputs 600 watts at 4 ohms (1x4 ohm speaker connected) and 1200 watts at 2 homs (2x4ohm speakers or dual 4 ohm voice coils in parallel).
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
I am looking to buy a 1200 watt jensen 2 channel amp. what model is this? is there a jensen 1200, i have not seem it.
I would recommend you purchase a brand name 600watt RMS amp instead of a Jensen 1200 watt peak amp. Trust me you will notice the difference. Try a kicker, hifonics, MTX, audiobahn Autotech... Its not the watts its the quality of the watts..
Jbl am in protect mode
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
JBL SR4732 amps????
I have a pair of these. Best audio thing I ever did. One amp as the the crossover is built into the amp. If you can find the compatible dual 18s then you'd need a second amp. Recently read a spec that they drop to 20 hz at 10 volts. So when you turn up the volume they rock with the bass truly showing a peak of their capability. These are just amazing. I originally used a crown xri4000. Just bought a Nad T 877 HT and when run only in stereo with QObuz, pretty incredible. Not the final purpose of this amp though. I may use the line outs to integrate the Crown Amps. Still getting an idea. So One powerful amp. You won't blow these out.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
