S/No TTF 90605659
SOURCE: lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
SOURCE: AG-790 teac
Same problem here. My first receiver was doing this, sent it back, and the second did it again. So I remembered an article regarding remotes and florecent lights. I covered up the remote sensor on the face of the receiver and so far no problem. A piece of tape about 1" square was used and so far no problems. [email protected]
SOURCE: Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
