Screen seems to be locked, how do I undo whatever it is I did to make this thing crazy?
Tablet turns on and off fine, not on home screen. Shows clock and calculator. Up arrow at bottom where home icon would normally be. Swiping up on arrow brings up a semi-circle with "Google" at top. Menu choice at top left does not respond either.
Try Reset your Tablet lol, this works with devices having physical home button:-
1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory. With NO physical HOME button:- 2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds. 3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings. NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
you can visit my blog to see video how to reset your tablet http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Try reset your tablet lol, his works with devices having physical home button:-
visit my blog to see video tutorial how to reset your tablet http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
This works with devices having physical home button:- 1. Press the power button and the home button together
Try to visit my blog to see video tutorial http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
or you can Check my blog how to reset your tablet lol,
Note: I Use My Tablet SUNBERRY, and reset my Tablet Turn Off your Tablet and then Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo) Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog you can see how to Reset android with video
Reset Factory from safe mode android, watch video in my blog
Reset factory setting from safemode menu,
check the video in my blog lol http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
I am also having the same issues with my E-295c tablet as well. Were
you able to figure out what your problem is? I thought mine may have
been my port replicator, but it continues after removing that. And mine
always seems to do it for sure everytime I have a full screen video playing. Thanks!
